yuvalkesi
Member level 5
I'm having a very strange problem with Active HDL. Dunno if it's only in Active, or maybe other simulators, cause this is the only one I got...
I'm writing a simple clock generator for a testbench for simulation.
I've tried 4 different methods. All should return the same clock, right (well, they're pretty straight forward...):
Clock generator 1:
iclk <= (not iclk) after 10ns;
Note: works fine.
Clock generator 2:
iclk <= '0' when (iclk = '1') else '1' after 10ns;
Note: doesn't work. Outputs '0'.
Clock generator 3:
process (iclk)
begin
if iclk = '1' then
iclk <= '0';
else
iclk <= '1' after 10ns;
end if;
end process;
Note: not working. this is the same code as Clock generator 2, just wrote it different (inside a process. Clk Gen 2 isn't inside a process).
Clock generator 4:
process
begin
iclk <= '0';
wait for 10ns;
iclk <= '1';
wait for 10ns;
end process;
Note: working fine.
So, my problems are with generators 2 & 3. Both output iclk of '0'.
Signal iclk is defined:
signal iclk : std_logic:='0';
Any ideas?
Is it Active HDL bug, or some silly mistake of my own?
Any help will do...
Thx!
Tom
Clock generator 1:
Note: works fine.
Clock generator 2:
Clock generator 3:
process (iclk)
begin
if iclk = '1' then
iclk <= '0';
else
end if;
end process;
Clock generator 4:
process
begin
iclk <= '0';
wait for 10ns;
iclk <= '1';
wait for 10ns;
end process;
Note: working fine.
Any ideas?
Any help will do...
Thx!
Tom
