Nov 13, 2008 #1 E eem2am Banned Joined Jun 22, 2008 Messages 1,179 Helped 37 Reputation 74 Reaction score 24 Trophy points 1,318 Activity points 0 smps voltage please i am trying to make off-line SMPS with variable output voltage 0 to 24V It is 50 Watt max, Is it right, all i need do is make the lower divider resistor variable like a pot ?
Nov 18, 2008 #2 grittinjames Advanced Member level 1 Joined Jun 1, 2006 Messages 479 Helped 44 Reputation 90 Reaction score 32 Trophy points 1,308 Location bangalore india Activity points 3,985 smps voltages hi, r u trying to make isolated one? if i think you can achive voltage as low as 1volt which is the forfard voltage of opto coupler usually
Nov 18, 2008 #3 E eem2am Banned Joined Jun 22, 2008 Messages 1,179 Helped 37 Reputation 74 Reaction score 24 Trophy points 1,318 Activity points 0 variable smps thankyou, yes it is isolated. so i just twiddle pot to vary voltage, but pot is a noisy resistor is it not ?....will it affect the smps?
Nov 19, 2008 #4 grittinjames Advanced Member level 1 Joined Jun 1, 2006 Messages 479 Helped 44 Reputation 90 Reaction score 32 Trophy points 1,308 Location bangalore india Activity points 3,985 what is voltage of smps its better to use tl431 and vary its reference. ys you may effected with ringing due to noisy resistoers. but with suitable prequation you can settile down it soon
Nov 19, 2008 #5 E eem2am Banned Joined Jun 22, 2008 Messages 1,179 Helped 37 Reputation 74 Reaction score 24 Trophy points 1,318 Activity points 0 variable voltage smps thankyou for replying , grittinnjames, ...though if i put a capacitor across the pot to smooth its voltage then i am messing up the loop gain. ...since the pot will be the lower divider resistor and this will surely mame my transient response terribly slow ?
Nov 20, 2008 #6 grittinjames Advanced Member level 1 Joined Jun 1, 2006 Messages 479 Helped 44 Reputation 90 Reaction score 32 Trophy points 1,308 Location bangalore india Activity points 3,985 smps voltaje use low value resistor divider say in 1k or below 10k i think it will help u to reduce noise
