variable resistor in LTspice?
fanshuo
Full Member level 5
Full Member level 5
Netherlands
ltspice variable resistor
how to create a variable resistor whose resistance could be changed in an arbitrary way, say sine wave, square wave and etc.
Thanks.
variable resistor ltspice
Here's an example. Let's say you want a resistor to vary its resistance sinusoidally between 500 ohms and 1500 ohms at a frequency of 1 Hz. All you do is add a resistor to the schematic as you would do normally but instead of specifying the resistor with a fixed value use this function instead:
R=1000+500*SIN(2*PI*TIME)
Look for .PARAM in the help topics for more functions you could try.
David
variable resistor in ltspice
I tried
.param RN=10+sin(400k*pi*time)
and I defined the value of the R1 is RN
the simulation shows warning that
"can't solve .param RN=10+sin(400k*pi*time)"
also I tried to set the resistor value directly as
sin(400k*pi*time)
then it react as"can not find the definition of model sin"
what should I do?
LaTeX Commands Quick-Menu:
