Variable gain amplifier
T
treez
Hello,
We need a variable gain amplifier. But very simple. The gain should be variable with a control voltage. Non-inverting.
Do you know of one.
All the Analog devices ones have way more features than we would like
We have a half sine control voltage which we wish to gradually vary the magnitude of. (ie not different discrete switchable gain levels)
Many possible solutions, different by linearity, noise and drift, bandwidth, accuracy and repeatability. Some specs needed.
its just the 100Hz half sine reference to a error amplifier of a pfc stage....we need to change its magnitude slowly. from 2v peak to 0v peak
A light-dependent resistor (usually Cadmium-sulfide cell) is an option.
A jfet varies its gain as you vary bias voltage. These are less readily available than they used to be.
Also consider a magnetic amplifier (made from a transformer). Gain is altered by running a DC voltage in one winding, while running the signal through the other winding.
For these types of uses, a CA3080 would fit the bill. But my understanding is that it is nowadays obsolete.
Now we know:
* 100Hz half sine
* 2V peak --> 0V peak
Any trimmer, any pot, any EEpot should do.
Klaus
