V23016-d0006-a201 siemens gp relay.
Kumarr
Newbie level 2
Malaysia
Hi there ,
i have a faulty siemens relay type v23016-d0006-a201 , the coil is open due to some fault.
I have downloaded the datasheet pdf file , but the language is in german.
Need to know the coil voltage ,resistance and the contact rating.
Are there any equivalent relay can be replaced.
d0006 refers to a coild voltage of 24V DC, 970 ohm nominal. A201 has a continuous current rating of 7.5 A
P.S.: Basically, most of the Siemens relais product sortiment has been continued by Tycoelectronics, but V23016 apparently isn't among them, I guess because the form factor is somewhat antique and too far from todays product mainstream.
Thanks for the information FvM , I really appreciate.
