V-scoring in Orcad layout? How?
farhada
Advanced Member level 2
Nice, France
v-scoring in layout
I am new in OrCad and wonder if anyone know how to do V-Scoring so I can have multiple designs on a same file for prototype manufacturing?
I have found a lot of info about the subject using google, but nothing about HOW to actually do it?!
Really appreciate your help,
Best regards,
/Farhad
orcad layout v groove
Scoring and other special fabrication instructions are done as notes on your drill drawing, a mechanical layer, and/or a separate fabrication instruction sheet - depending on what your fab is accustomed to seeing. The notes are instructions to your PCB fab concerning exactly what you want to do.
You put your scoring lines on a mechanical Gerber layer. The PCB fab then uses the lines and your notes to make the scoring after the panel has been fabricated. The scoring is done with a router bit.
You should contact your fab and find out how they prefer to receive their instructions.
    farhada
orcad layout fab
i give two holes for the straight line and inform the PCB manufacturer that a V groove is required.
There are seperate machines for V grooving.
    farhada
pcb v-groove fab drawing
Thank you all.
I will try it out to see how it works in my current project. Hopefully I can save a few bucks doing so.
BR,
/Farhad
