Please help me in plotting the gain in HFSS. I go through these steps: result/ far field report/rectangular plot /antenna params/ Peak gain or peak realized gain / and set solution in context to sweep and primary sweep to freq, and press new report, but the HFSS does not give me result. It keeps loading!!
It is an UWB antenna. Its bandwidth is from 2 to 12 GHz. I use the fast sweep. I clicked the save fields.
It starts loading once i choose the sweep from solution box to the right side of create rectangular plot.
In previous versions of HFSS, a discrete sweep was required. This might still be the case in newer versions (I'm not sure) -- if you can't get your plot working try it out.
In the project manager look for the reflector antenna icon ...... make sure you have set up a far field sphere to calculate radiation patterns in the first place.
