Thái Xuân H
Newbie level 3
Hi all,
I have a SPI interface, it has three modes to transfer the data out on IO[0:7]. In SPI standard there is just IO[0] is used. QPI mode, it uses IO[3:0] and In OPI mode, the whole IO are used. When driver receives a req from sequencer, it drives that req to the interface depending on modes. The interface sometimes goes with SPI, sometimes QPI or OPI. And I want to monitor the tx data, but I dont't know how to setup the monitor to sample the data corresponding to the mode that the driver has used. Are there ways to make monitor works in the same mode with the driver?
Thank you!
Thank you!
