Grimsmeer
Newbie level 1
Hi.
Is it possible to make a 5V PCI-card work without a PC? I have a PCI-card whitch function is to output for example a 75MHz signal through an integrated output.
Would it work, if i would give the card all the voltages it requires? Or does it still need some kind of a clock signal.
As far as I know, the card is not operated by any PC program. So I wouldn't need to communicate with the card in any way.
There's lots of pinouts available on the net, but are all the 5V, 3,3V and grounds actually required?
I would be very greatful for your help.
