Using H-Bridge instead of L293 or L298 for control of DC brush motor
snmeciut
Member level 4
Member level 4
Dear
I saw that usually l293 or l298 was used for control of the dc brush motor.but i used l298 and saw that dissipation of this IC is high,so IC is warmed high.
I think that a simple H-Bridge with IRF9540 and IRF530 with low resistance and dissipation is powerfull than these IC's.
please send your comment
h bridge irf 530
IR 2110 is Good for H - Bridge Control.
Regards
Rahul :wink:
h bridge irf530
I've used the l298... is really a headache, it keeps burning and the pins break when u are most frudtrated.
If you can use other IC i think you should!!!
irf530 h bridge pwm
I second the IR2110.
Also take a look at the Unitrode motor control ICs here (Unitrode is now a part of Texas Instruments)
Select the parts based on your specifications
Best regards,
v_c
motor dc irf530
you must match your motor specification with l293, i am able to controll 2 motor using this IC
