[SOLVED] Using D flip-flop to get complementary output.
snaku
Junior Member level 3
Bangalore
Hi All,
I have to design a circuit such that I have an input and I have to get complementary outputs. I am supposed to use D flip-flop and importantly with no clock. I have thought of doing it by only using preset(bar) and clear input and I do not use d and clk input. I have attached the circuit image. When input is high, the output is (Q=1, Qb=0) and when the input is low, the output is (Q=0, Qb=1).. Pllease, let me know if this works.
The "PRE" and the "CLR" pins must have different states at any given instance of time.
Connect the input directly to the "CLR" pins and, the output of the inverter to the "PRE" pin.
Check this reference:
Reactions: snaku
    snaku
