Jul 29, 2007 #1 hmsheng Full Member level 4 Joined Dec 17, 2003 Messages 219 Helped 26 Reputation 52 Reaction score 10 Trophy points 1,298 Location China Activity points 1,556 I want to use a dataset from a text file as a signal source in ADS simulation. The dataset has following format: time valtage 1e-9 1 2e-9 2 3e-9 -1 4e-9 -2 5e-9 -3 6e-9 0 ... ... The voltage should keep 1ns, that is, from 1ns to 2ns it should be 1V, from 2ns to 3ns it should be 2V, ..., from 5ns to 6ns it should be -3V, ... How to realize it???
Jul 30, 2007 #2 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 Re: ADS help use the spice type source and enter the voltage and time manually.
Jul 31, 2007 #3 B berserkfy Newbie level 2 Joined May 10, 2005 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,288 Re: ADS help you can try source-time domain -> BitSeq
Aug 2, 2007 #4 Sadegh.j Advanced Member level 3 Joined Nov 29, 2006 Messages 749 Helped 48 Reputation 98 Reaction score 15 Trophy points 1,298 Activity points 5,585 Re: ADS help Can you use the sweeping capability? it is not what you looking for, I know. I wonder if you can do it on ADS. If it is possible, I also want to learn it.
Aug 2, 2007 #5 hmsheng Full Member level 4 Joined Dec 17, 2003 Messages 219 Helped 26 Reputation 52 Reaction score 10 Trophy points 1,298 Location China Activity points 1,556 ADS help Dear all , The problem is solved by using DAC (Data Access Component) in ADS. Save the data file as .tim format. Plz refer the file format on ADS help. Then read the data from the file with DAC in simulation.
