Hi...explaining my doubt again..incase there is anybody who has used the IP before do help..
I have a master.sv file which has the code for SPI master. I have written a basic testbench
(master_tb.sv)to test the master, but to simulate the SPI bus I wanted to use a verification IP already provided by sysWip(
http://syswip.com).
The VIP has an interface file and a package file.
How do I use it in my code?
where do I instantiate the interface, start the spi environment and the connection?
do I need to change anything in my master.sv file?
my master.sv file is given below
module master
input clk,
output sdi,
input sdo,
output sclk,
output [2:0] slave_select
i have just typed the code for the test bench.
module master_tb();
wire sclk;
reg clk;
reg sdo;
wire sdi;
wire [2:0] slave_select;
master_tb dut(
.sclk(sclk),
.sdo(sdo),
and so on
where do i do the import of the interface?
do i need master interface too? or just the slave interfcae is needed to test my code?
Is there any simple sample code availbale?
