I am trying to incorporate a RF power detector in my circuit at C-band to understand if a discontinious cable or a rusty connector exists between my antenna and PA.
I have a circulator after my PA to protect the circuit for reflections. Circulator's unused port is terminated with 50ohm to dissipate the power reflected from mismatches(normally). I want to show a 50 ohm termination to that port while simultaneously sampling the power in-line with a detector.
---Can I use a 0 db attenuator to show circulator's 3rd port 50 ohm termination while sampling the reflected power with a RF power detector. I tried drawing a schematic where normal lines are forward power and dashed lines are reflected power in case of a discontinuity, is this logical?
Thanks for replying. That's the part I'm struggling to figure out, if reasonable. If not properly terminated circulator does not work; hence I thought maybe a 0-db attenuator will provide the 50-ohm match to circulator. In MaximIntegrated site there is a similar topology given; picture below.
This is the datasheet of the 0-db attenuator I mentioned.
From your datasheet, that is a series of SMD attentuators. Different values including 0 dB can be used for post-layout level adjustment.
The attenuator will improve matching by 2*A dB, where A is the attenuator value in dB. The 0dB will behave like any other thru line, it doesn't improve return loss.
