aliyesami
Full Member level 6
if i use a normal 9v square battery , how long can i run the atmega1284P on it with minimal components? the datasheet of this micro says 0.4mA only when active.
thanks
thanks
Note: This feature currently requires accessing the site using the built-in Safari browser.
ok i bought LT1521CST-3.3#PBF-ND LDO
I will be running the atmega1284 at about 11Mhz so how much power it will consume? i cant find this info in datasheet.
i will add a 220uf cap on the output.
thanks
these 1.5 and 1uf capacitors should be polar?
also how can i measure the total current draw for a circuit ? i have a current meter in my multimeter and I once tried to measure the current by putting the multimeter in series on the positive rail but it blew up the micro controller together with other components on the board.
thanks
