electronical
hello , how can i use matlab in ise or ise in matlab?
thankyou,have you any pdf or site that I learn faster issue?Both.
Matlab in ISE: Matlab has new feature called HDL coder that you can export HDL from Matlab Simulink models, which can then be used in ISE for FPGA implementation
ISE in Matlab: ISE DSP edition has a tool called System Generator, which you can use in Simulink to create models for FPGA implementation.
I want to import an array of std_logic that created by matlab to ise or modelsim, then the recieved result from ise or modelsim export to matlab.
by reguard,
