use instrumentation amplifier as op amp
qwertu
There are a lot of discussions about when instrumentation amplifier should be used instead of op amp. My question is: since instrumentation amplifier looks superior, can I just use it to replace op amp? If cost is not the consideration here.
DZC
Full Member level 3
I think so.
Instrumentation amplifiers are ideally suited as the name suggests for Instrumentaion applications as they have many specialties like hIgher CMRR etc. but using it in circuits that require just one opamp doesn't make sense.
qwertu
First, thank you for your reply.
Well, it make sense in my application if it works just as well. My question is whether it will do the job of an op amp, or whether I can just replace an op amp in my circuit to an instrument amplifier.
Higher CMRR won't be a bad thing for me.
FvM
Super Moderator
Staff member
Bochum, Germany
Generally, it's not said that the circuit would work at all. Instrumentation amps have built-in fixed gain and are not intended for external feedback. Op amps have (ideally) infinite gain and can't be operated without external feedback (except as a comparator).
Apart from that, it may be useful for particular circuits to use an instrumentation amp instead of an opamp, but not generally.
