peterpops
Junior Member level 3
- Joined
- Mar 17, 2010
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Sweden
- Activity points
- 1,492
Hi!
Scenario:
I have a USB port powering 20 relays and a microcontroller (uC) relaycontrol
Relay current consumption ~15mA each
uC current consumption ~1mA
Questions: (I'm looking for the ways to calculate/model this theoretical, and what equations should I use)
1. If I have all the relays deactivated and then activates all of them at the same time (total current ~300mA). Will this impact the USB voltage, will I see a significant drop in voltage, maybe enough to reset the uC?
2. If it affects the voltage significantly, should I use a condensator (except the one the uC probably wants)? If so, what value?
3. Even if it does not affect the voltage significantly is it good pratice to have a condensator here (except the one the uC probably wants)?
Thanks in advance!
Scenario:
Thanks in advance!
