Just connect it, it does not need program.
No need programming. Just follow the connection of its datasheet. There is an example circuit. Also, it is possible to request for unique PID (Product ID) from Silabs for making ur device unique. U will only need to program the CP2102 for changing the default PID to a unique PID using their software if needed. And this can only be done after u hv successfully made the circuit. Upon successfully implemented, u will need to install 2 drivers in the computer when u plug in. One driver is for virtual COM port, another is for USB device driver.xwcwc1234 said:Hwo to use CP2102 ? Should I program it ?
