eepty
Full Member level 2
I have developed a system in which each device can communicate with each other through RS485. In the protocol, if a device want to send out a packet, it will detect the RS485 bus first to check if any data still on the bus to avoid collision. The system work perfectly within its own network. It also works when I use a RS232-to-RS485 converter to connect a computer to this system. However, if I use a USB-to-RS485 converter, I found that the data crashed.
What could be the reason?
Thanks!
Thanks!
