vsmGuy said:I think the gtp-usb is an illegal clone and the firmware is somehow copyrighted ?
Or am I wrong ?
Making it would be illegal - would it not ?
Kripton2035 said:well I'm not veering off anything...
just wanted to say that this programmer is not worth building...
seems to work as it seems that nobody has built it ...
Kripton2035 said:there is also a "small" problem...
where is the pic firmware..????
nomad13 said:Well my friend there is no need for the firmware because this is just another JDM programmer. The 16c/f84 in the diagram is a programming socket for similar kind of MCU. The connector on the other hand is used for microcontroller of different pin assignment.
nomad13 said:Yes you may say that this programmer is not worth building...
But for others who just want to start on building their own programmer this may worth a try.
badboy2007 said:if i want to make JDM version USB, how i do?
best regard,
badboy2007
nomad13 said:badboy2007 said:if i want to make JDM version USB, how i do?
best regard,
badboy2007
JDM is a serial port programmer and I dont know if anybody tried using a usb to serial converter on this. But for me it doesn't work so I switch to pickit2.
badboy2007 said:
