Apr 9, 2012 #1 J jivaniakash Newbie level 3 Joined Aug 23, 2011 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,296 hi, i want to interface pen drive with pic18f4550 can any on give how i make a program to read/write data and display in LCD
Apr 9, 2012 #2 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 jivaniakash said: i want to interface pen drive with pic18f4550 can any on give how i make a program to read/write data and display in LCD Click to expand... A USB flash/pen drive requires a USB Host Interface, the PIC18F4550 does not support an Embedded Host/OTG Interface. **broken link removed** Consider using a SD/MMC instead, which only requires a SPI interface and the PIC18F4550 does support. Or utilize a third party interface device which supports Embedded Host/OTG, FTDI and Maxim both manufacture such a device. Or utilize a PIC24 or PIC32 in your design. BigDog
Apr 10, 2012 #3 J jivaniakash Newbie level 3 Joined Aug 23, 2011 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,296 thanks sir ---------- Post added at 22:01 ---------- Previous post was at 21:46 ---------- plz, give me code for SD/MMC with pic18f4550 to display on 128x64 GLCD
Apr 10, 2012 #4 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 Are you coding in C or Assembler? If C Language, what compiler are you using? BigDog
Apr 11, 2012 #5 J jivaniakash Newbie level 3 Joined Aug 23, 2011 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,296 C coding Language in MPLAB IDEv8.76 and MPLAB C18 C Compiler thanks,
