URGENT CRC Calculation required..............
Guru59
Full Member level 4
The following is a frame used in RX Block of OPENCORE 10G
data[0] = 32'h04030201;
data[1] = 32'h02020605;
data[2] = 32'h06050403;
data[3] = 32'h55AA2E00;
data[4] = 32'hAA55AA55;
data[5] = 32'h55AA55AA;
data[6] = 32'hAA55AA55;
data[7] = 32'h55AA55AA;
data[8] = 32'hAA55AA55;
data[9] = 32'h55AA55AA;
data[10] = 32'hAA55AA55;
data[11] = 32'h55AA55AA;
data[12] = 32'hAA55AA55;
data[13] = 32'h55AA55AA;
data[14] = 32'hAA55AA55;
crc = 32'hF620480D
The CRC given is from the Opencore People..........
As i try to calculate the CRC it is coming differently..............
i used the following Code for calculating CRC........
I Desperately Need your Help.................
Hello Someone PLZ..................
Its Urgent..................
Thanks
Just reverse the input data_in before computing CRC. U will get correct answer.
Added after 8 minutes:
If not give intial value to all ones
    Guru59
