Christian Chetcuti
Junior Member level 3
I have read in various literature books that the baud rate generator in a UART module should generate a signal whose sampling frequency is exactly 16 times the UART's designated baud rate.
For a 57600 baud rate, the sampling rate of the signal would therefore be => 16 x 57600 => 921600 samples per second, am i right?
Would i need to upsample this 921600s/S signal given that I would then need to multiply this signal by a carrier wave and then output it using a DAC (PMOD DA2) whose sampling rate is that of 1000000 samples per second?
