I have a small UPS (APC Back-UPS 350) that has a 12 volt 7aH battery. I use it to keep my router and cable modem up and running in case of a power outage. I recently got a couple of Group 24 wheelchair deep cycle batteries. Can I connect these in parallel to the 12 volt battery in the unit to greatly improve the up time of the UPS? Do I need to provide a seperate battery charger/tender for the Group 24s and somehow "isolate" them from the UPS? What other considerations are there? I don't want to burn up the UPS.
This was all covered in previous posts.tpetar said:*
1. Can I connect these in parallel to the 12 volt battery in the unit to greatly improve the up time of the UPS?*
You can everything, but this is not good. Paralleling batteries of different size and chemistry not good. ...........(snipped for brevity).........)
According to his own account, the OP has limited experience in electronics. Explanations and suggested solutions are best given to suit an OP's level of understanding. If the UPS's internal charger and and external charger are connected at the same time, there's no way of knowing how they will interact unless the design details of both charging circuits are known.tpetar said:*2. Do I need to provide a seperate battery charger/tender*
Yes. UPS charging 7,2Ah battery with max 0,7A. You can put 100Ah you will get only 0,7A charging. If lead acid chemistry of battery this is bad, only because needed time for charging. Lead Acid should put on charge, immediately after fully discharging. Should put some charger (float charger 13,8V or 13,5V if voltage higher from ups charging voltage then ups will pull power from charger).
These are all general comments on good battery charging practice. Not really relevant to the OP's situation.tpetar said:_*_3. Charger should be float charge with limited current._*_ ........(snipped for brevity)........ DO NOT LEAVE LEAD ACID DISCHARGED FOR LONGER TIME, RECHARGE IT IMMEDIATELY !!!!
tpetar said:*4. LM317 have internal current and thermal shutdown* limit for protection of IC. You can ask for more amperage but you will get only what you get, not over 1,5A for LM317 if datasheet conditions are fulfilled. We talk about LM317 maybe you have LM338T or something else, check circuit and device parts, maybe is not at all LM317. You can shortcut LM317 LM338 and nothing, you cant killing like that, they have internal current limit protection and thermal protection. Maybe 0,7A charging need smaller heatsink (obviously), if you pull 1,5A constant for longer time, then semiconductor will work on higher temp, and shorten his life, you should improve cooling. But what I know, current in UPS is limited to 0,7A!!!!!!!! Gelled lead acid 7Ah are charged with 0,7A recommended according to datasheets, max 1A-1,1A but on what temperature. In UPS device temperature is very HOT!!! Trafo core is small and very hot, designed to work several minutes, not hours, battery is sticked together with
trafo.
That is when the UPS is working at or near its maximum rated power. In the OP's case, he's running it at perhaps less than one-tenth of its rated capacity. Any UPS that cannot run indefinitely at that load will be a very very poorly designed one.tpetar said:*5. Standard PC UPS not designed for longer working time.* They are designed to take over on few minutes not for hours and hours, because that cooling and heatsinks are small, you need to put some additional cooler/fan, I mean bigger 12V like for power supply 7x7cm, should I dare to say to increase heatsink (replacing with bigger). Trafo core is smaller then should be. Because that temperature rising in case of device, shorten battery life. Should put some nice fans there. Also there is larger expensive server room UPS, I mean real UPS, but price hmm hmmm :roll: this nice devices are designed to work on longer times.
Again this is irrelevant to the thread because the OP want to use them only for very light loads.tpetar said:*6. You mention deep cycle batteries,* this type of batteries, are different from starter. They charging and discharging with smaller current. Not appropriate for UPS usage, Ok only if you plan to use bank of this batteries and special chargers for them. Lead acid starter and deep cycle are different types, but familiar chemistry. Its long story, but in few words, starter is for higher amperage for shorten time, 100A-200A (depends from capacity) for few seconds, and not for total disharging. If you go to 10,5V this can kill or drasticaly decrease capacity and health of battery. Simple its float battery about 70% level or 30% discharging is Ok. But deep cycle can go to deep discharge, but you cant pull high amperage from it. Higher amperage can melt plate, and kill battery.
I hope that you know what you say. If you read and understand my post you will understand. When you paralleling different batteries even the same tech. and capacity, if internal resistance is not the same, one will draw power from another.Pjdd said:2. Some years ago, I needed an extra UPS for one of my computers. I had an old APC UPS that I had discarded a few years because the battery was no longer usable and I didn't bother replacing it. I also had an old car battery that I had replaced with a new one because it was no longer good enough for use in a car. I combined the two without any external charger and it served me well for a long time.
UPS cant stay cool it any operation. It warm up during regular funcioning. Maybe you have some ups in fridge.Pjdd said:1. Two month ago (last November), I used a small UPS to run a light load at an outdoor sporting event where there was no mains power. I used it for several hours everyday for 3 consecutive days. It stayed cool.
This is not true! All UPS is designed for their purposes. You must read manufacturer user manual and other data. Manufacturer make UPS (we talking about regular desktop PC UPS) for giving backup time of few minutes to 30-45min. Because that they puting smaller heatskinks, and battery is not 10000Ah but 7Ah.Pjdd said:Any UPS that cannot run indefinitely at that load will be a very very poorly designed one.
You didnt read what I write, or you didnt read carefully. I say he need additional charger. 0,7A is enough for charging bigger batteries.Pjdd said:If you're talking about the charging transformer, they are not designed to operate for just a few minutes. A 0.7A charger will take about 15 hours to fully charge a 7.5Ah battery. If the charger cannot run for more than a few minutes, the battery will never get charged to a useful level. .... ....
Again you didnt read my text carefully. I said : Should put some charger (float charger 13,8V or 13,5V if voltage higher from ups charging voltage then ups will pull power from charger).Pjdd said:If the UPS's internal charger and and external charger are connected at the same time, there's no way of knowing how they will interact unless the design details of both charging circuits are known.
Pjdd I respect any people with their level, he ask some question I answer it. Maybe he is prof. on some university and just open account on edaboard.tpetar said:According to his own account, the OP has limited experience in electronics. Explanations and suggested solutions are best given to suit an OP's level of understanding.
This is not true! All UPS is designed for their purposes. You must read manufacturer user manual and other data. Manufacturer make UPS (we talking about regular desktop PC UPS) for giving backup time of few minutes to 30-45min or some other defined time. Because that they puting smaller heatskinks, and battery is not 10000Ah but 7Ah.Any UPS that cannot run indefinitely at that load will be a very very poorly designed one.
You didnt read what I write, or you didnt read carefully. I say he need additional charger. 0,7A is enough for charging bigger batteries.If you're talking about the charging transformer, they are not designed to operate for just a few minutes. A 0.7A charger will take about 15 hours to fully charge a 7.5Ah battery. If the charger cannot run for more than a few minutes, the battery will never get charged to a useful level. .... ....
Again you didnt read my text carefully. I said : Should put some charger (float charger 13,8V or 13,5V if voltage higher from ups charging voltage then ups will pull power from charger). Its a basic Pjdd you should know this, that always higher potencial goes to lower potencial first.If the UPS's internal charger and and external charger are connected at the same time, there's no way of knowing how they will interact unless the design details of both charging circuits are known.
There's no need to be sarcastic. "Cool" is a relative term. If you live in a place where summer temperatures reach 45°C, 35°C will feel cool. If your local tempearture seldom goes over 30°C (as it is where I live), 28°C feels quite hot.UPS cant stay cool it any operation. It warm up during regular funcioning. Maybe you have some ups in fridge.Originally Posted by Pjdd
I have used desktop UPSes at light load for long periods many times. The incident I related was just one example. Manufacturers don't always include all possible information. They provide information for situations in which their product is used for its main purpose. But in the real world, we often use a product for purposes other than the main intended application.This is not true! All UPS is designed for their purposes. You must read manufacturer user manual and other data. Manufacturer make UPS (we talking about regular desktop PC UPS) for giving backup time of few minutes to 30-45min. Because that they puting smaller heatskinks, and battery is not 10000Ah but 7Ah.Any UPS that cannot run indefinitely at that load will be a very very poorly designed one.
It is you who did not read my post carefully. The UPS will certainly try to pull in power from the higher voltage from the external charger. BUT that may be harmful to the UPS. For example, if the UPS charger has no protection against reverse current from an external higher voltage, it could well destroy the UPS's internal charger.Again you didnt read my text carefully. I said : Should put some charger (float charger 13,8V or 13,5V if voltage higher from ups charging voltage then ups will pull power from charger).If the UPS's internal charger and and external charger are connected at the same time, there's no way of knowing how they will interact unless the design details of both charging circuits are known.
This is one of those misunderstandings that may be due to a language problem. "According to his own account" means "From what he said about himself". It does not refer to his account at edaboard.Pjdd I respect any people with their level, he ask some question I answer it. Maybe he is prof. on some university and just open account on edaboard.According to his own account, the OP has limited experience in electronics. Explanations and suggested solutions are best given to suit an OP's level of understanding.
Please tell us what I send you. Or we should ask admins what is rude in PM.But I'll appreciate it if you stopped sending me rude PMs.
The answer should have been to ease the guidance seeker not to put him in confusion. I can not say this post is going in which direction and how far we are gone but still his REQUESTED INFORMATION is awaited. My humble request to all is that please put some simple reply and let him be satisfied.I have a small UPS (APC Back-UPS 350) that has a 12 volt 7aH battery. I use it to keep my router and cable modem up and running in case of a power outage. I recently got a couple of Group 24 wheelchair deep cycle batteries. Can I connect these in parallel to the 12 volt battery in the unit to greatly improve the up time of the UPS? Do I need to provide a seperate battery charger/tender for the Group 24s and somehow "isolate" them from the UPS? What other considerations are there? I don't want to burn up the UPS.
To all my colleagues,
The original question was very simple,
HOPE my requested will be honored.
Again my request that the TOLERANCE IS THE BEST WAY. We can be in discussion for years to each other but I feel the the question poster expects a nice and easy way of guidance, so please.............................!
We are all friends of course, there should not be space for angry. Sometimes bad thing happen but we are all humans, we are all brothers and sisters. Sometimes confrontation of opinions make great solution. Sometimes we have to add some additional heat to make better sword from steel.I really did not intend to start a fight. I really am a novice and don't understand a lot of the theory being debated.
There was some mention of an inverter in an earlier post which raises a question (hopefully without starting another fight).
Of course you can! But that inverter must have possibility to be a UPS. You can add 200Ah if you whant, you will get more UPS time. On market, there are inverters and ups (ups also have inverter inside), standard inverter devices dont have ups possibility.Can you use a larger capacity battery with an appropriate charge to power an inverter to act as a UPS?
Yes my friend, if mains is present, UPS giving power from mains, if lose mains power ups (name of ups told everything), then ups fast switch on inverter. Inverter get power from battery. For attaching charger on inverter I write in my post I think #27.Basically the charger would be supplying power to the inverter while mains was on and the battery would take over if mains fails. Is this in essence what the UPS does or is there some sort of switching between mains and battery when power fails?
I have UPS working several years on big batteries with chargers on it, without problems, but I just make cooling stronger. I add some additional bigger fans, open cases on some places...I bring this up because it seems to me that an inverter is designed to run for an extended period of time and not just a few minutes like some posters suggested concerning desktop UPS units.
I don't understand, lead acid batteries are supposed to need a constant current cycle in the first stage of the charge, how does a constant voltage method like the above provide a proper charge?
I'm not experienced at all with USP so I'm just asking these questions to help me understand the circuit operation.
I did a search for LM317 lead acid charger but the circuits I found included some kind of current limiting
