unknown Error in VHDL
Jaffry
Member level 1
Hi all,
I have an unknown and irritating error in VHDL, I have declared my signals as std_logic, but I recieve the following error for my case strucure. (I have put both error and code snippet below)
Line 128: Type std_logic does not match with the integer literal
architecure behavahioral of data_ent is
signal sel_f, sel_opath : std_logic_vector(1 downto 0);
signal wr_enf0, wr_enf1, wr_enf2, wr_enf3 : std_logic;
--wr_en is the input signal with type std_logic
begin
process(sel_f,wr_en)
begin
case sel_f is
when "00" => wr_enf0 <= wr_en; wr_enf1 <= '0'; wr_enf2 <= 0; wr_enf3 <= 0;
when "01" => wr_enf1 <= wr_en; wr_enf0 <= '0'; wr_enf2 <= 0; wr_enf3 <= 0;
when "10" => wr_enf2 <= wr_en; wr_enf0 <= '0'; wr_enf1 <= 0; wr_enf3 <= 0;
when "11" => wr_enf3 <= wr_en; wr_enf0 <= '0'; wr_enf2 <= 0; wr_enf1 <= 0;
when others => wr_enf0 <= '0'; wr_enf1 <= '0'; wr_enf2 <= 0; wr_enf3 <= 0;
end case;
end process;
Please suggest what is wrong. What does it means by integer literal.
bests,
Jaffry
literal -- a hard-coded value with no other name. (eg, not a named constant or generic but rather something like "0100111")
your issue is that 0 is an integer value, "0" is a std_logic_vector, and '0' is a std_logic. you used 0 when you should have used '0'.
Yes it is a silly mistake which took almost half of my day trying and trying to rectifiy, later I saw that I just did not put single quotes with zeros...'0'
Thank you again
Jaffry
wr_enf1<='0';wr_enf2<='0';wr_enf3<='0', because they are std_logic and you should be careful!
Good luck!
