CherryQ
Junior Member level 1
Hi all,
I want to design a buffer after the differential Opamp stage to drive large load capacitance. The buffer requires small gain and the same CM level with my input differential signal, so I use an inverter with feedback resistor R. By tuning R, I got almost unity gain, and by tuning the inverter NMOS and PMOS, I got the desired output CM. However, I found one stage of this buffer is not sufficient for my load cap. I am wondering if I can cascode several this kind of buffers. Because the gain drops significantly even though I have unity gain for each buffer.
Any comments will be appreciated.
