Understanding DDR3 DRAM configuration
shaiko
Advanced Member level 5
Hello,
I'm trying to learn about the various configuration options of DDR3 memory.
For example, please review the following document:
At Page 11, Table 2, Row 2 - you see this:
1Gb / (8M × 16 × 8) × 2 SDRAMs
This is how I understand it:
1Gb - Is the total capacity of the DRAM chip.
8M - Is the size of every memory sub-array. It is organized internally into rows and columns (CAS/RAS) when every row/column intersection addresses only a single bit per sub-array.
16 - Is the width of the input/output data of the chip. A single bit comes from every memory sub-array and concatenated to the total width. Therefore, the width exactly matches the number of memory sub-arrays per bank.
8 - Is the number of banks per dram chip.
Is my observation correct?
shaiko
How are different banks accessed on the same DRAM chip?
Does every bank have a different offset row address?
shaiko
Thanks for your help.
This is one of the (many) documents I've stumbled upon before posting.
It has good information about timing, but doesn't discuss memory configuration in detail.
