Milruwan
Member level 1
- Joined
- Jan 20, 2013
- Messages
- 35
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,546
Sir,
I tried to undersample a band limited signal which is 10.7MHz and it's
bandwidth is 200kHz. I undersample the signal and got the signal into
250kHz to 450KHz range.Then I tried to low pass filter the signal(0Hz to
450kHz). But the filtered signal was distorted.
My question is can I under sample a signal and L.P.F the signal in this
way?
Or is there a better way to do undersampling and recover the band
limited signal?
way?
limited signal?
