thierrywalt
Newbie level 1
Hello! I am new here... So, I am a beginner trying to develop a circuit, and I sometimes I get confused about power supplies. If I have a DC power supply rated at, let's say, 12V and 10A, and I connect a device that is supposed to operate at 12V and 5A, everything would be fine, right? The current passing through the device depends only on its resistance, because after all it is like a simple resistor, it does not depend on capacity of the power supply (as long as it is lower), right? Why, then, people say that LED's "draw as much current as they can"? If the voltage is the same, then their resistance varies according to the current? Or is the resistance always the same? If I connected a 3V LED to this power supply, would it draw all the 10A? If so, what other devices display this behavior?
Ok. Now, if I connect a device (thermoelectric cooler) to the same power supply, being that this device is supposed to work at 12V but will draw 15A, what would happen? The current needed is higher than the power supply can supply. Would the device simply operate at a lower potency (the voltage is the same but the current is lower) or would the power supply burn?
Thanks in advance!
Thanks in advance!
