I have 500 watt inverter , so when the battery voltage drob or become low the internal fuse of inverter blowen and in most case one of mosfet transistor that switghing the 12vdc to high freq. is also damage,so please i need to put an protection to protect my inverter from this ,can any have an idea to solve this problem?
U need to put an Opamp (comparator) in the Switching section of Input side, which will go shut down the switching of primary or supply to inverter section and shut down inverter...if u provide me with ur diagram of inverter, i might tell u where to fit the scheme, it will help in overvoltage protection also.
Hi, you mention that your that your mosfet get burnt any time your battery went low can you tell me the mosfet is it the high frequency side or the low frequency 50Hz,also D16 and D19 Suppose to be connected to your vcc
I will need some time to study the Schematic of ur inverter, in the meanwhile what I can suggest is u put some comparator Opamps in the path of Error Amplifier pin of KA3525. I dont know much about 3525, but I have worked with 7500. but in my case, we stop the supply in auxiliary transformer which will stop further working of both push-pull as well as inverter section. I wil send u the page where u can find the scheme, and if implemented with same value of resistors, ur inverter should stop working when input voltaghe goes below 10.8V or above 14.4V.
