Unbalanced supplies to Op-Amp
Pha5e
Full Member level 1
I am not here - it's an illusion
What are the implications of using Op-Amps with unbalanced supplies i.e. V+ at +10V and V- at approximately -9.50V?
The circuit is for a potentiostat and consists of two Op-Amps. One op-Amp is configured in negative feedback mode to generate a fixed reference voltage. The other Op-Amp is configured as a Trans-Impedance-Amplifier to measure the working electrode.
Neither Op-Amp is operating to saturation.
Thanks.
The off-set voltage should be minimum for good op-amp. when we use two different power supplies then offset voltage increases.
Using different plus and minus supply voltages is the same as changing the common-mode input voltage. Normally an op-amp common-mode rejection is very high so it will have only a very small effect on the op amp characteristics. It is unlikely to affect the (differential) offset voltage.
Generally lower supply voltage on a specific rail causes lower maximum output voltage excursion for that rail. So for +10V and -9.5V supply rails maximum undistorted output voltage can be 19Vpp.
This actually depends on type of OPA and its parameters.
