Unable to write characters to LCD from PIC with HiTech C
the_merovingian
Member level 1
UK
I'm converting some of my code from assembler to HiTech PICC C. I'm using a PIC16F672A.
The following code doesn't seem to work correctly. It correctly initiates the LCD (i.e. I can see the dim glow of both lines as it's 2x16, the cursor is present & blinks etc), but when the code goes to write some character data the LCD just goes blank.
I've tested RS and it does go high.
RB0:3 = DB4:7
RA1 = EN
RA3 = RS
Any ideas?
#include <htc.h>
__CONFIG(BOREN & UNPROTECT & UNPROTECT & PWRTEN & WDTDIS & LVPDIS & MCLREN & INTIO);
#define	lcd_cursor(x)	lcd_write(((x)&0x7F)|0x80)
#ifndef _XTAL_FREQ
 // Unless specified elsewhere, 4MHz system frequency is assumed
 #define _XTAL_FREQ 4000000
#endif
#define	LCD_RS RA3
#define  LCD_EN RA1
#define  LCD_DATA	PORTB
#define	LCD_STROBE()	((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void
lcd_write(unsigned char c)
	__delay_ms(40);
	LCD_DATA = ( ( c >> 4 ) & 0x0F );
	LCD_STROBE();
	LCD_DATA = ( c & 0x0F );
	LCD_STROBE();
 * 	Clear and home the LCD
void
lcd_clear(void)
	LCD_RS = 0;
	lcd_write(0x1);
	__delay_ms(2);
/* write a string of chars to the LCD */
void
lcd_puts(const char * s)
	LCD_RS = 1;	// write characters
	while(*s)
		lcd_write(*s++);
/* write one character to the LCD */
void
lcd_putch(char c)
	lcd_write( c );
 * Go to the specified position
void
lcd_goto(unsigned char pos)
	LCD_RS = 0;
	lcd_write(0x80+pos);
/* initialise the LCD - put into 4 bit mode */
void
lcd_init()
	char init_value;
	init_value = 0x3;
	TRISA=0;
	TRISB=0;
	LCD_RS = 0;
	LCD_EN = 0;
	/* LCD_RW = 0; not required - RW tied low */
	__delay_ms(15);	// wait 15mSec after power applied,
	LCD_DATA	 = init_value;
	LCD_STROBE();
	__delay_ms(5);
	LCD_STROBE();
	__delay_ms(50);
	LCD_STROBE();
	__delay_ms(50);
	LCD_DATA = 2;	// Four bit mode
	LCD_STROBE();
	lcd_write(0x28); // Set interface length
	lcd_write(0xF); // Display On, Cursor On, Cursor Blink
	lcd_clear();	// Clear screen
	lcd_write(0x6); // Set entry Mode
	lcd_write(0x2); // return home
void main(void)
	lcd_init();
	__delay_ms(50);
/* this doesn't work:
	lcd_puts("Hello world");
/* ...neither does this, which should present the character "U" : */
	LCD_RS = 1;
	__delay_ms(50);
   LCD_DATA = 0x05;
	LCD_STROBE();
	__delay_ms(50);
   LCD_DATA = 0x05;
	LCD_STROBE();
	for(;;);
Added after 2 hours 48 minutes:
I've figured this one out myself... I forgot to disable the onboard comparators!!
Amendment for those of you interest:
void main(void)
   CMCON = 0x07; // disable comparators
	lcd_init();
The problem you are facing is due to timings. Check out the lcd datasheet and apply proper timing for each instructions
Nandhu
No - as I stated above the problem was related to the comparators being enabled.
There is nothing wrong with those timings - they are over generous if anything.
hello friends
as per my knowledge
In 16X2 LCD, There is ADDRESS for each location(one Matrix(5x7) of black dot) .
and The Address for first line is start from 0x80 to 0x8f
and the address for second line is start from 0xC0 to 0xCF
to write any character to LCD
first send address for location and then send character to print that location
sorry for my poor English
Regards
Ghanshym dudhat
Yes, you are correct, hence the:
void lcd_goto(unsigned char pos)
   LCD_RS = 0;
But, as stated above, that wasn't the problem.
in your above code ,
from where, you are calling function(lcd_write();)
i think, your main function is write to like this type
void main(void)
lcd_init();
__delay_ms(50);
lcd_goto(0x00);
lcd_goto(0x00);
LCD_RS = 1;
__delay_ms(50);
LCD_DATA = 0x05;
LCD_STROBE();
__delay_ms(50);
LCD_DATA = 0x05;
LCD_STROBE();
for(;;);
Regard
Ghanshyam
For the first write it is in the correct position, this is due to the following code:
