electronutIN
Newbie level 2
I am trying to get my Arduino Pro Mini to talk to an nRF905 module using the RadioHead library:
https://www.airspayce.com/mikem/arduino/RadioHead/
I was not able to get the simple client server example to work.
I was, however able to get Zak Kemble's library below to work with my hardware:
https://github.com/zkemble/nRF905
When I compared the code between the libraries, I found that RadioHead was not setting the PWR_UP pin for the nRF905. It's also missing the connections for DR and CD. The only recommended connections are (from RH_NRF905.h):
I was wondering if anyone was able to get RadioHead to work with nRF905 with just the above connections.
Thanks.
/// CPU nRF905 module
156 /// 3V3----------VCC (3.3V)
157 /// pin D8-----------CE (chip enable in)
158 /// pin D9-----------TX_EN (transmit enable in)
159 /// SS pin D10----------CSN (chip select in)
160 /// SCK pin D13----------SCK (SPI clock in)
161 /// MOSI pin D11----------MOSI (SPI Data in)
162 /// MISO pin D12----------MISO (SPI data out)
163 /// GND----------GND (ground in)
Thanks.
