What's the input?
I think it won't be easy to get this circuit to work. It depends rather sensibly on the threshold voltages of your process. And you'd have to adapt the individual W/L ratios to your technology - it probably won't work with the given - all the same - W/L ratios.
You can't change these values. They are fixed with an individual production process.1. How to change the threshold of a transistor, kp, lambda in cadence?
relative error tolerance, a simulation control parameter which you can set in your simulation control file.2. what is reltol?
What - exactly - is your struggling problem?I am struggling with one more circuit. The circuit is originally designed in 0.36um technology. The circuit is a modified version the circuit for which you have helped me(i.e axon hillock circuit). The circuit is attached below.
