aruna1
Member level 1
Hi
I'm working on a ultrasonic transmitter and using transducer pair like in image I attached.
Currently I'm giving 9V (7809) to drive the transducer (TX) through a H-bridge.
My question is;
I have read in internet that these transmitter drums can operate voltages up to 20V and as the voltage increase the transmission distance increases.I don't have any datasheet on the module and it doesn't have any model number or reference.
So is it possible to use a charge pump system to boost 5V supply to 15V and use this 15V to drive the transducer? Since charge pumps cant deliver large current I wonder whether this is possible. But if it possible it will save me from making an inductor based boost converter.
If this is possible what is the maximum ultrasonic burst duration I can achieve with charge pump?
I wonder how they do it on ultrasonic range finder modules like SRF05, they work with 5V.
as I'm using 9V currently I was able to send ultrasonic signal to about 25m. but this is possible only If I'm transmitting continues 40KHz stream.
But if I send 40KHz burst , receiver sometimes failed to grab it even at distance of 8m and receiver is already using gain of 1360.
please note this system is not using the reflected ultrasonic signal. transmitter and receiver are in two different places and used to measure the distance between transmitter and receive.
I want to send a super power ultrasonic burst so my receiver wont miss it at 20m
My question is;
