// PIC16F877 + SRF05 + LCD03 example
// Written October 2005 by Gerald Coe, using HITECH PIC16 compiler
// Performs ranging using just a single pin on the PIC16F877 (RB0)
// Note - assumes a 20MHz crystal, which is 5MHz timer clock
// A 1:4 prescaler is used to give a 1.25MHz timer count (0.8uS per tick)
// This code is Freeware - Use it for any purpose you like.
#include <htc.h>
#include <stdio.h>
__CONFIG(0x3b32); // configuration register - see PIC data sheet for details
#define TrgEch RB0
#define TrgDir TRISB0
void clrscn(void); // prototypes
void cursor(char pos);
void print(char *p);
void setup(void);
unsigned int get_srf05(void);
char s[21]; // buffer used to hold text to print
void main(void)
unsigned int range;
setup(); // sets up the PIC16F877 I2C port
clrscn(); // clears the LCD03 disply
cursor(2); // sets cursor to 1st row of LCD03
sprintf(s,"SRF05 Ranger Test"); // text, printed into our buffer
print(s); // send it to the LCD03
while(1) { // loop forever
range = get_srf05(); // get range from srf05 (round trip flight time in 0.8uS units)
cursor(24); // sets cursor to 2nd row of LCD03
sprintf(s,"Range = %dcm ", range/72); // convert to cm
cursor(44); // sets cursor to 3rd row of LCD03
sprintf(s,"Range = %dinch ", range/185); // convert to inches
TMR1H = 0; // 52mS delay - this is so that the srf05 ranging is not too rapid
TMR1L = 0; // and the previous pulse has faded away before we start the next one
T1CON = 0x21; // 1:4 prescale and running
TMR1IF = 0;
while(!TMR1IF); // wait for delay time
TMR1ON = 0; // stop timer
TMR1H = 0xff; // prepare timer for 10uS pulse
TMR1L = -14;
TMR1IF = 0;
TrgDir = 0; // make trigger/echo pin an output
TrgEch = 1; // start trigger pulse
while(!TMR1IF); // wait 10uS
TrgEch = 0; // end trigger pulse
TrgDir = 1; // make trigger/echo pin an input
TMR1H = 0; // prepare timer to measure echo pulse
TMR1L = 0;
T1CON = 0x20; // 1:4 prescale but not running yet
TMR1IF = 0;
while(!TrgEch && !TMR1IF); // wait for echo pulse to start (go high)
TMR1ON = 1; // start timer to measure pulse
while(TrgEch && !TMR1IF); // wait for echo pulse to stop (go low)
TrgDir = 0; // make trigger/echo pin an output again
return (TMR1H<<8)+TMR1L; // TMR1H:TMR1L contains flight time of the pulse in 0.8uS units
void clrscn(void)
SEN = 1; // send start bit
while(SEN); // and wait for it to clear
SSPIF = 0;
SSPBUF = 0xc6; // LCD02 I2C address
while(!SSPIF); // wait for interrupt
SSPIF = 0; // then clear it.
SSPBUF = 0; // address of register to write to
while(!SSPIF); //
SSPIF = 0; //
SSPBUF = 12; // clear screen
while(!SSPIF); //
SSPIF = 0; //
SSPBUF = 4; // cursor off
while(!SSPIF); //
SSPIF = 0; //
PEN = 1; // send stop bit
while(PEN); //
SSPIF = 0;
while(!SSPIF); //
SSPIF = 0; //
SSPBUF = 2; // set cursor
while(!SSPIF); //
SSPIF = 0; //
SSPBUF = pos; //
while(!SSPIF); //
SSPIF = 0; //
while(PEN); //
void print(char *p)
SSPIF = 0;
while(!SSPIF); //
SSPIF = 0; //
while(*p) {
SSPBUF = *p++; // write the data
while(!SSPIF); //
SSPIF = 0; //
while(PEN); //
void setup(void)
unsigned long x;
PORTB = 0xfe; // RB0 (trig) is output
TRISB = 0xfe; // and starts low
TRISC = 0xff;
PORTC = 0xff;
SSPSTAT = 0x80;
SSPCON = 0x38;
SSPCON2 = 0x00;
SSPADD = 50; // SCL = 91khz with 20Mhz Osc
for(x=0; x<300000L; x++); // wait for LCD03 to initialise
