peterpops
Junior Member level 3
Hi EDA!
I want to switch a relay with my uC. What options do I have? I'm new to transistors (and electronics in general =])
I'm using a PIC18F4550 and the relay I want to switch is a V23026A (TE-Connectivity).
1. I guess I can use the uC directly to switch the relay since it is possible to source/sink a current up to 20mA and the relay needs around 5V/330Ohm = 15mA. In this case do I need any protective circuits and is there something I should have in mind?
2. A friend told me I can use darlington transistors for this. Is there a unit which has all protective circuits already include in the package? or do I still need some discrete components?
3. Is there another simple way to do this? MOSFET? Again any protective circuits needed for this?
I don't want something big because I'm running out of space on my PCB.. because when I search for Darlington transistor I find a Darlington array ULN2803A with 6 and 8 outputs with all the protective ciruits included. But I don't have need for the other 5 or 7 outputs.. Can't find an equal single darlington with the same protective circuits include
Thanks in Advance!
/Peter
Thanks in Advance!
/Peter
