uC/OS-II port for the Freescale MC9S12XEP100
peustace
Newbie level 1
ucos-ii mc9s12xep100
I'm writing a uC/OS-II port for the MC9S12XEP100 microcontroller. This a port for this chip isnt listed on the micrium website. Can anyone suggest a similar port to work with?
And I'd really appreciate any tips for writing this port! I've been reading Labrosse's book but its not making much sense to me. I understand all the concepts behind RTOSs but the code is alluding me at the moment.
Thanks again
Pat
os_cpu_a.s s3c2440
AA,
I had a similar project. My goal was to write ucos-ii port on S3C2440. I did not find it on ucos-ii website. I picked up a processor near mine S3C2410. I started from there. My changes were as follows:
1. Changing some initialization code
2. Changing some interrupt vectors
3. Changing Ports initializations
4. Changing registers used in the already exisiting modules.
I noticed that there are two processors, similar to yours. You can start from there as I did.
BR,
Amr Ali.
ucos-ii mc9s12xep100 下载
Thank you sir.
freescale ucos
I wrote uC/OS-II port for MC9S12XA256 recently.
Here is two most important files. I have the whole test project, please email me if you want.
* uC/OS-II
* The Real-Time Kernel
* (c) Copyright 1998, Jean J. Labrosse, Plantation, FL
* All Rights Reserved
* M68HC12XA256 Specific code
* (MetroWerks CodeWarrior C/C++ V4.5)
* File : OS_CPU_C.C
* By : Jean J. Labrosse
* Port Version : V1.0
* Ported to MC68HC12XA256: Zhiliang Xu
#include "INCLUDES.H"
* INITIALIZE A TASK'S STACK
* Description: This function is called by either OSTaskCreate() or OSTaskCreateExt() to initialize the
* stack frame of the task being created. This function is highly processor specific.
* Arguments : task is a pointer to the task code
* pdata is a pointer to a user supplied data area that will be passed to the task
* when the task first executes.
* ptos is a pointer to the top of stack. It is assumed that 'ptos' points to
* a 'free' entry on the task stack. If OS_STK_GROWTH is set to 1 then
* 'ptos' will contain the HIGHEST valid address of the stack. Similarly, if
* OS_STK_GROWTH is set to 0, the 'ptos' will contains the LOWEST valid address
* of the stack.
* opt specifies options that can be used to alter the behavior of OSTaskStkInit().
* (see uCOS_II.H for OS_TASK_OPT_???).
* Returns : Always returns the location of the new top-of-stack' once the processor registers have
* been placed on the stack in the proper order.
* Note(s) : 1) XIRQ interrupts are disabled when your task starts executing. You can change this by
* clearing BIT6 in the CCR.
* 2) The STOP instruction is disabled when your task starts executing. You can change this
* by clearing BIT7 in the CCR.
* 3) The other interrupts (i.e. maskable interrupts) are enabled when your task starts
* executing. You can change this by setting BIT4 in the CCR.
* 4) You can change pass the above options in the 'opt' argument. You MUST only use the
* upper 8 bits of 'opt' because the lower bits are reserved by uC/OS-II. If you make
* changes to the code below, you will need to ensure that it doesn't affect the behaviour
* of OSTaskIdle() and OSTaskStat().
* 5) Registers are initialized to make them easy to differentiate with a debugger.
//OS_STK *OSTaskStkInit(void (*task)(void *pd), void *pdata, void *ptos, INT16U opt);
OS_STK *OSTaskStkInit (void (*task)(void *pd), void *pdata, void *ptos, INT16U opt)
INT16U *wstk;
INT8U *bstk;
INT32U temp;
temp = (INT32U)task;
opt = opt; /* 'opt' is not used, prevent warning */
wstk = (INT16U *)ptos; /* Load stack pointer */
*--wstk = (INT16U)pdata; /* Simulate call to function with argument */
*--wstk = (INT16U)(temp>>8);
*--wstk = (INT16U)(temp>>8); /* Put pointer to task on top of stack */
*--wstk = (INT16U)0x2222; /* Y Register */
*--wstk = (INT16U)0x1111; /* X Register */
*--wstk = (INT16U)0xBBAA; /* D Register */
bstk = (INT8U *)wstk; /* Convert WORD ptr to BYTE ptr to set CCR */
*--bstk = 0xC0; /* CCR Register (Disable STOP instruction) */
*--bstk = 0x00; /* CCR Register (Disable STOP instruction) */
return ((void *)bstk); /* Return pointer to new top-of-stack */
/*$PAGE*/
#if OS_CPU_HOOKS_EN
* TASK CREATION HOOK
* Description: This function is called when a task is created.
* Arguments : ptcb is a pointer to the task control block of the task being created.
* Note(s) : 1) Interrupts are disabled during this call.
void OSTaskCreateHook (OS_TCB *ptcb)
ptcb = ptcb; /* Prevent compiler warning */
* TASK DELETION HOOK
* Description: This function is called when a task is deleted.
* Arguments : ptcb is a pointer to the task control block of the task being deleted.
void OSTaskDelHook (OS_TCB *ptcb)
* TASK SWITCH HOOK
* Description: This function is called when a task switch is performed. This allows you to perform other
* operations during a context switch.
* Arguments : none
* 2) It is assumed that the global pointer 'OSTCBHighRdy' points to the TCB of the task that
* will be 'switched in' (i.e. the highest priority task) and, 'OSTCBCur' points to the
* task being switched out (i.e. the preempted task).
void OSTaskSwHook (void)
* STATISTIC TASK HOOK
* Description: This function is called every second by uC/OS-II's statistics task. This allows your
* application to add functionality to the statistics task.
* Arguments : none
void OSTaskStatHook (void)
* TICK HOOK
* Description: This function is called every tick.
* Arguments : none
* Note(s) : 1) Interrupts may or may not be ENABLED during this call.
void OSTimeTickHook (void)
#endif
#if OS_VERSION >= 251
void OSTCBInitHook (OS_TCB *ptcb)
ptcb = ptcb; /* Prevent Compiler warning */
#endif
void OSInitHookBegin (void)
#endif
void OSTaskIdleHook (void)
#endif
void OSInitHookEnd (void)
#endif
; uC/OS-II
; The Real-Time Kernel
; (c) Copyright 1998, Jean J. Labrosse, Plantation, FL
; All Rights Reserved
; M68HC12XA256 Specific code
; (CodeWarrior C/C++ V4.5)
; File : OS_CPU_A.S
; By : Jean J. Labrosse
; Port Version : V1.02
; Ported to MC68HC12XA256 : Zhiliang Xu
; CONFIGURATION CONSTANTS
OS_TICK_OC: equ 7 ; We will use Output Compare #7 to generate tick interrupts
OS_TICK_OC_CNTS: equ 461 ; 1000 Hz tick rate (assumes Free Running Timer runs at 460.8 KHz)
; OS_TICK_OC_CNTS = CPU_FRT_FREQ / OS_TICKS_PER_SEC
; I/O PORT ADDRESSES
TFLG1: equ $004E ; I/O port addresses. Assumes all 68HC12 I/Os start at 0x0000
TC0: equ $0050
TC1: equ $0052
TC2: equ $0054
TC3: equ $0056
TC4: equ $0058
TC5: equ $005A
TC6: equ $005C
TC7: equ $005E
; PUBLIC DECLARATIONS
xdef OSStartHighRdy
xdef OSCtxSw
xdef OSIntCtxSw
xdef OSTickISR
xdef _Null
; EXTERNAL DECLARATIONS
xref OSIntExit
xref OSIntNesting
xref OSPrioCur
xref OSPrioHighRdy
xref OSRunning
xref OSTaskSwHook
xref OSTCBCur
xref OSTCBHighRdy
xref OSTimeTick
; START HIGHEST PRIORITY TASK READY-TO-RUN
; Description : This function is called by OSStart() to start the highest priority task that was created
; by your application before calling OSStart().
; Arguments : none
; Note(s) : 1) The stack frame is assumed to look as follows:
; OSTCBHighRdy->OSTCBStkPtr + 0 --> CCR(H)
; + 1 CCR(L)
; + 2 B
; + 3 A
; + 4 X (H)
; + 5 X (L)
; + 6 Y (H)
; + 7 Y (L)
; + 8 PC(H)
; + 9 PC(L)
; 2) OSStartHighRdy() MUST:
; a) Call OSTaskSwHook() then,
; b) Set OSRunning to TRUE,
; c) Switch to the highest priority task.
NON_BANKED: SECTION
OSStartHighRdy:
call OSTaskSwHook ; 4~, Invoke user defined context switch hook
inc OSRunning ; 4~, Indicate that we are multitasking
ldx OSTCBHighRdy ; 3~, Point to TCB of highest priority task ready to run
lds 0,x ; 3~, Load SP into 68HC12
rti ; 8~, Run task
; TASK LEVEL CONTEXT SWITCH
; Description : This function is called when a task makes a higher priority task ready-to-run.
; Arguments : none
; Note(s) : 1) Upon entry,
; OSTCBCur points to the OS_TCB of the task to suspend
; OSTCBHighRdy points to the OS_TCB of the task to resume
; 2) The stack frame of the task to suspend looks as follows:
; SP + 0 --> CCR(H)
; + 1 CCR(L)
; + 2 B
; + 3 A
; + 4 X (H)
; + 5 X (L)
; + 6 Y (H)
; + 7 Y (L)
; + 8 PC(H)
; + 9 PC(L)
; 3) The stack frame of the task to resume looks as follows:
; + 1 CCR(L)
; + 2 B
; + 3 A
; + 4 X (H)
; + 5 X (L)
; + 6 Y (H)
; + 7 Y (L)
; + 8 PC(H)
; + 9 PC(L)
OSCtxSw:
ldx OSTCBCur ; 3~, Point to current task's TCB
sts 0,x ; 3~, Save stack pointer in preempted task's TCB
call OSTaskSwHook ; 4~, Call user task switch hook
ldx OSTCBHighRdy ; 3~, OSTCBCur = OSTCBHighRdy
stx OSTCBCur ; 3~
ldab OSPrioHighRdy ; 3~, OSPrioCur = OSPrioHighRdy
stab OSPrioCur ; 3~
rti ; 8~, Run task
; INTERRUPT LEVEL CONTEXT SWITCH
; Description : This function is called by OSIntExit() to perform a context switch to a task that has
; been made ready-to-run by an ISR.
; Arguments : none
; Note(s) : 1) Stack frame upon entry (Assuming OS_CRITICAL_METHOD is 1):
; ---- SP + 0 -> Page \ Return address from call to OSIntCtxSw()
; | SP + 1 -> PC(H) \ Return address from call to OSIntCtxSw()
; SP Adjustment | SP + 2 -> PC(L) /
; ---- SP + 3 -> Page \ Return address from call to OSIntCtxSw()
; (+6) | SP + 4 -> PC(H) \ Return address from call to OSIntExit()
; --> SP + 5 -> PC(L) /
; SP + 6 -> CCR(H) \
; SP + 7 -> CCR(L) |
; SP + 7 -> B |
; SP + 8 -> A |
; SP + 9 -> X(H) | Stack frame from interrupt stacking.
; SP + 10 -> X(L) |
; SP + 11 -> Y(H) |
; SP + 12 -> Y(L) |
; SP + 13 -> PC(H) |
; SP + 14 -> PC(L) /
OSIntCtxSw:
leas 6,sp ; 2~, Clean up stack (Uncomment if OS_CRITICAL_METHOD is 1)
ldy OSTCBCur ; 3~, OSTCBCur->OSTCBStkPtr = Stack Pointer
sts 0,y ; 3~,
stx OSTCBCur ; 3~
stab OSPrioCur ; 3~
rti ; 8~, Run task
; SYSTEM TICK ISR
; Description : This function is the ISR used to notify uC/OS-II that a system tick has occurred. You
; must setup the 68HC12's interrupt vector table so that an OUTPUT COMPARE interrupt
; vectors to this function.
; Arguments : none
; Notes : 1) The 'tick ISR' assumes the we are using the Output Compare specified by OS_TICK_OC
; (see OS_CFG.H and this file) to generate a tick that occurs every OS_TICK_OC_CNTS
; (see OS_CFG.H and this file) which corresponds to the number of FRT (Free Running
; Timer) counts to the next interrupt.
; 2) You must specify which output compare will be used by the tick ISR as follows:
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 0 to use OUTPUT COMPARE #0
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 1 to use OUTPUT COMPARE #1
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 2 to use OUTPUT COMPARE #2
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 3 to use OUTPUT COMPARE #3
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 4 to use OUTPUT COMPARE #4
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 5 to use OUTPUT COMPARE #5
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 6 to use OUTPUT COMPARE #6
; Set OS_TICK_OC in OS_CFG.H (AND in this file) to 7 to use OUTPUT COMPARE #7
; 3) TFLG1, TC0 ... TC7 are defined in this file.
OSTickISR:
inc OSIntNesting ; 4~, Notify uC/OS-II about ISR
; if OS_TICK_OC == 7
ldab #$80 ; 2~, Clear C7F interrupt flag (bit 7)
stab TFLG1 ; 4~
ldd TC7 ; 5~, Set TC7 to present time + desired counts to next ISR
addd #OS_TICK_OC_CNTS ; 4~
std TC7 ; 5~
; endif
cli ; 2~, Enable interrupts to allow interrupt nesting
call OSTimeTick ; 6~+, Call uC/OS-II's tick updating function
call OSIntExit ; 6~+, Notify uC/OS-II about end of ISR
rti ; 12~, Return from interrupt, no higher priority tasks ready.
_Null
stop
