Hello all my post readers,
I am very new to FPGA, a weak ago started playing with a spartan 6. (Papilio pro). Now connected a 320x240 LCD to it and planning to do something with that as a hello world. I have a decent experience on electronics hardware, digital circuits and embedded firmware development. But first time with FPGA. Learning VHDL now.
I started with some documents and getting started guide from Papilio website.
Now able to understand the vhdl and it's syntax to an extent.
I did a small UART TX as my first program. It is working fine.
Now I want to keep that UART TX as a function equivalent. I want to keep that uart_tx: process(CLK) as a module and from another process I want to trigger the UART stat state machine.
I am able to trigger from external process by setting a 1 bit signal variable. I can read it from uart_tx process but I cannot clear it from there because yes two processes cannot asynchronously write to a single signal, I can imagine this.
So generally how people do this ?
Because I want to keep the UART TX isolated from other code and don't want to write anything inside that process. And if possible I want to keep it as a seperate file aswell so that I can invoke transmit trigger and set transmit byte from other vhdl file or other process in same file.
I can think of another option which is something like keeping two counter incrementing (at least 1 bit or higher) so that I just need to increment both counters on sending trigger(from main process) and sent complete response (from uart_tx process/uart seperate tx library file). But I am sure this may be a dirty way.
Can someone throw some light?
Also I have another question, all independent statements under a process will happen parallel and dependent things will follow sequential. Is this correct?
A bit difficult to visualise from an embedded programmer point of view.
