markkthemk
Newbie level 2
- Joined
- Sep 29, 2010
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Netherlands
- Activity points
- 1,299
Hey Guys,
This is my first time posting on this website so bear with me.
I am a new user to VHDL so I don't know much about it.
For my studies I have a getting started to help me learn VHDL.
The problem is that there is a bug in the provided code.
This code is supposed to provide a test set to see what will happen to outputs a and b (if i understand correctly).
It also shows how to write particular parts of the code in different ways.
The problem lies in the following 2 lines
giving these error messages (compiled in ModelSim 10.1b student version):
stim_a_groter_b.vhd(19): Type conversion (to UNSIGNED) can not have aggregate operand.
stim_a_groter_b.vhd(19): Illegal type conversion to ieee.std_logic_1164.STD_LOGIC_VECTOR (operand type is not known).
stim_a_groter_b.vhd(20): Type conversion (to UNSIGNED) can not have aggregate operand.
stim_a_groter_b.vhd(20): Illegal type conversion to ieee.std_logic_1164.STD_LOGIC_VECTOR (operand type is not known).
stim_a_groter_b.vhd(28): VHDL Compiler exiting
I'm pretty sure other people have also had this error. I have googled it a bit and found some problems/answers. However, I don't know enough about the language yet to actually interpret the answers in a way that I can use them.
I hope you will be able to help me
Mark.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity stim_a_groter_b is
Port ( a,b : out STD_LOGIC_VECTOR (3 downto 0));
end stim_a_groter_b;
architecture Behavioral of stim_a_groter_b is
begin
process
constant maximum_integer_a : integer := 2**4-1;
constant max_int_b : integer := 2**b'length-1;
begin
for i in 0 to maximum_integer_a loop
for j in 0 to max_int_b loop
a <= std_logic_vector(unsigned(i,4));
b <= std_logic_vector(unsigned(j,b'length));
wait for 10 ns;
end loop;
end loop;
report "klaar" severity note;
wait;
end process;
end Behavioral;
Mark.
