Shachar85
Member level 2
Hi
I would like to build a small project with remote control.
I found that TX-2B RX-2B are the main components that I need, and found this pdf:
which tells me how to build the circuit I need (page9).
1.will it make difference if I used 150p capacitor instead of 151p and 500p instead 501?
2. what is L3 inductor in the right side of the upper circuit? (0.3mmX5mm?)
3. what are the two M in the lower circuit?
4. there's a resistor on the lower circuit, just above the RX-2B that says 3.9MO. does it mean 3.9 mega ohm?
thanks for any help
---------- Post added at 02:14 ---------- Previous post was at 02:14 ----------
the pdf:
thanks for any help
the pdf:
