sj95 said:Dear all:
If I have the below two floor plan, will the guard ring B work well as guard ring A ?
THX
Guard ring A (enclose all analog):
Digital
________
| Analog|
| Analog|
|______|
Guard ring B (the furthest guard ring is ignored):
Digital
_______
|Analog|
|Analog|
thanks
leohart said:Hi,even we use the guard ring A,will the noise coupled into analog part from the substrate right under it? We know the digital and analog are on the same sub,the guard ring give isolation only to certain to depth of sub.
Brittoo said:leohart said:Hi,even we use the guard ring A,will the noise coupled into analog part from the substrate right under it? We know the digital and analog are on the same sub,the guard ring give isolation only to certain to depth of sub.
hi leohart
If the net is noisy / critical one then , you could go for shielding(box shielding preferably) with power rauils. that wud definitely help. isolate the quiet analog from the noisy digital part .
regards
Brittoo
leohart said:Brittoo said:leohart said:Hi,even we use the guard ring A,will the noise coupled into analog part from the substrate right under it? We know the digital and analog are on the same sub,the guard ring give isolation only to certain to depth of sub.
hi leohart
regards
Brittoo
hi my question is "will noise be coupled from the substrate right under even though we have used guardring"...the analog part in the guardring is still connect with noisey part through "the substrate right under analog part->substrate under guardring->substrate of noisey part"
I dont know if I have make myself clear...
Anyway,what is a box shielding?What's the difference between this one and guardring
THX!
scottieman said:should a guard ring surrounding the digital circuits more efective than that surrounding the analog part?
