joe2005
Newbie level 3
I am a beginner at this but I am doing some circuits and I have those questions:
1- I need a device/circuit that acts exactly like a relay ie. when a little DC volt is applied is closes another circuit. The this is that I don't want to use a relay due to its sound (yes I have frequent switching). I want this device/circuit to be able to allow both AC and DC signals through up to 220VAC and to be able to handle at least a couple of Amperes. Any Suggestions...pleeaaaaaase
2- I am trying to build a circuit that acts as a switch between the 220VAC mains and a light bulb. Simply put, the light is off and you press the button, the light bulb gradually lights up until it reaches its max in 10 seconds. The lights is now on and you press the button, the light gradually fades in 10 seconds. I don't care to change a thing in the "steady state" part between the on and the off. Now the thing is that I do NOT want to use a variable resistance. I only want a simple "click". Please give me all the ideas possible.
Thank you alllllllllllll
