T
treez
Hello,
I have twelve TO220 resistors all screwed to the same heatsink face (with heatsink paste) , each resistor is dissipating 20W (240W total). The resistor legs are mounted on a PCB which is 145mm by about 50mm. (you can see the resistors and the PCB below)
The resistors are LTO030F22R00JTE3 resistors as follows.......
LTO030F22R00JTE3 resistor datasheet.....
https://uk.farnell.com/vishay-sfern...-film-22r-5-30w-to-220/dp/9567011?Ntt=9567011
Do you think that since these resistors are so closely mounted together, they will overheat..?
The heatsink is a "350AB" type from ABL Heatsinks (25cm long) , as follows ......
https://www.abl-heatsinks.co.uk/index.php?page=extrudedproduct&product=163
There heatsink is vertically mounted with a fan blowing air up from undeneath it.....
The fan is as follows...(4710KL-05W-B50)
https://www.nmbtc.com/pdf/dcfans/4710kl.pdf
PCB comprising the 12 TO220 resistors (with dimensions)
https://i41.tinypic.com/2dlix08.jpg
....you can see the resistors body lying flat as they would be screwed to the heatsink face.
