Disha Karnataki
Full Member level 5
- Joined
- Jul 20, 2013
- Messages
- 249
- Helped
- 9
- Reputation
- 18
- Reaction score
- 8
- Trophy points
- 18
- Location
- india
- Activity points
- 2,231
i have connected a tsop1738 to my atmega8L.
as per the characteristics of tsop1738 it detects signal only when signal frequency is of 38khz.
circut as shown:https://www.8051projects.info/images/thumb351437.GIF
i have already connected to 8051 microcontroller it worked fine over there.
But when i connected this to atmega8 it continuously started executing the isr routine though there was no key pressed on remote control(as tsop detects only that).
I have written a code where the ISR routine displays some message on LCD connected to it.
So i switched off the lights of my room thinking the lights may be causing the signal to go low on the ext interrupt pin,& yes that was the real problem. Even if i touched the tsop it again caused the interrupt.
Why is TSOP sensing the room light & my touch?
each & every time i on the tubelight it is executing the ISR causing interrupt to the uc.
whereas it should only detect the remote control carrier frequency.
