I have designed my circuit with the width of 60nm, however the minimum size of this tech file is 600nm!
I have a 90nm tech file with the minimum size of 120nm. Why the minimum size of 45nm tech file is 600nm!
As fredd said. If you have 90nm process it means there is the smallest gate of transistor with this length (90nm). It doesn't mean that every transistor in this technology must have this minimum length! No way sir.
Not at all.
Is that 600nm common one or any special one? Has this tsmc 45nm any optional masks?
Usually the smallest transistor is Low Voltage and it requires a special mask pretty often .
