1. The supply voltage is 3.3 volt in TSMC 0.35um CM process. Can I use 1.8v supply voltage instead of 3.3 volt in Vdd ? Because 2nd stage input voltage is too high, I had better use different supply voltage in 1st stage and 2nd stage.
2. Supply voltage is 3.3 volt for this process. Which one can I use Vdd =3.3v and Vss=-3.3 v or Vdd = 1.65 v and Vss =-1.65 v ?
