Trying to send SMS from PC via my Mobile using AT Commands
vahidiau
Newbie level 3
samsung at command e900
First Hello Everybody.........
I have a Samsung ( SGH-D900i ) Mobile set.
I'm trying to send SMS from PC via my Mobile using AT Commands
I know D900 Supports At+Cmgf=1 ( text mode )
in hyper terminal :
at+cmgf=1 ( Enter )
// returns OK.
at+cmgs="xxx" ( Enter )
// Show me >
OK.
i type my text and (Ctrl+z)
But Nothing found.! -------------> with no error or message..
what should i do???????!!!!!
Samsung D900 is very good in supporting AT Commands. but i don't know
why it doesn't send SMS via AT Commands..........
Help me..... PLZ*** PLZ***
GSM Man
Banned
New Jersey, USA
URGENT!!!
I'd say that it looks like the Mobile is not getting the CTL-Z. Are you sure that Hyperterminal is passing this charater through to the serial port - I don't use Hyperterminal so I don't know what it does with control characters.
vahidiau
Newbie level 3
Re: URGENT!!!
Hello..!
Yes. i've sent sms with another mobiles using hyper terminal , and just samsung D900 does'nt work.!! WITH NO ERRORS!
√ but i'm agree with your idea about recognizing Ctrl+z //..........
victorio79
Newbie level 1
Hungary
Re: Trying to send SMS from PC via my Mobile using AT Comman
I had the same problem. Simply use the Break or Ctrl+Break intead of Ctrl+Z.
Despite that Break sends Ctrl+C, pressing Ctrl+C not works for me. Maybe the casue is the same as with the WinDbebug:
Note that in WinDbg, CTRL+C is a shortcut key that is used to copy text from a window. To issue a break command in WinDbg, use CTRL+BREAK or select Debug | Break from the menu.
Anyway this is nebulous for me.
vahidiau
Newbie level 3
Hey Guys.....
I Found the problem....
the CTRL+Z which you type in hyper terminal is unknown for Samsung D900 ((and maybe some other models)) .. JUST THIS..
so in other environments and programming languages like VB.net , C#.net,...
there is no problem and it works absolutely.!!
