haadi20
Full Member level 1
I encounter a difference in the simulated value of VCO output frequency when i run transient and PSS simulation...is this normal? has anybody experienced the same issue?
As an e.g. I get a frequency of 37 GHz from transient simulation (by using the frequency function from the calculator on the differential output voltage)
Whereas, the PSS finds an oscillation frequency of 38 GHz. I use Moderate as errpreset.
My question is which simulation result should i trust in designing for a specific tuning range?
Regards
Regards
